True, however something is not right.Bill Fitzmaurice wrote:
The huge bump around 1.5kHz is the result of the very high sensitivity of the BMS, while the severe roll off above that 'plateau' is typical of CD horns, which trade off flat axial response for wide dispersion.
The amount of variation in horn response seems too high. Perhaps the P-Audio horn used is not a good candidate.
Are these boxes biamped? Regardless, what are the crossover specs? Perhaps inadequate slopes are accounting for the huge bump in terms of allowing combined output from both the LF and HF drivers.
Here's what you should be seeing in terms of raw HF performance on a 90x75 horn:
http://bmsspeakers.com/fileadmin/bms-da ... curves.jpg
Certainly the typical CD/horn roll off is expected, but not to the extent in the measurements taken. I've measured many good HF drivers and they usually look smoother than this even unprocessed. It is expected that you need to EQ the CD, but this seems extreme, suggesting either contribution of the LF driver in the measurement due to crossover inadequacy, or the PAudio horn not being ideal.
