How well does PL stick to metal?
I remember another topic where somebody mentioned using something like this as something for the feet of Otops or Jacks to sink into while stacking. But after hearing so many storiess about spun H-nuts and the like I wondered if using PL to fasten these to our cabs would work, or if they would just easily get knocked out or fall off over time (and yes that little hole in the corner would obviously have to get covered up)?
Re: How well does PL stick to metal?
If my experience with T-nuts is any representation... not very well at all. PL is supposed to stay "permanently flexible".
Epoxy seems the way to go.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
- SoundInMotionDJ
PL is not sufficient for H-nuts. I have used Gorilla Glue, and a 2 stage epoxy. The Epoxy is defiantly better...but there is a lot more waste...unless you have 15 to 20 H-nuts to glue down in a 15 minute window of time.
--Stan Graves
--Stan Graves
10 T39S + 10 DR200 + 1 T48
It doesn't. Peels right off.
Disheartening.
Epoxy would be the best then?
Yes.
I'm getting closer to my home: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 602_263622
If we could find something like this without the hole in the middle I think we would be in pretty good business.
I have bought bits and pieces from that seller, and can recommend.la malta wrote:I'm getting closer to my home: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 602_263622
I plan on potting in t-nuts with epoxy mixed with glass shards, it was recommended to me by the supply house.
Sandblast or scrape up the fasteners somehow, as the epoxy needs something to bind to - and the smooth zinc coating is less then ideal.
-More to come!
-More to come!
