DCX Woes
Re: DCX Woes
Better not use a soldering gun. Rohs compliant soldering these days requires a high temperature tip, but not huge like the average soldering gun as that may heat up the board and surrounding components too much. It's better to run a regulated soldering station with a small tip.
bgavin
Re: DCX Woes
A leaning cap is not a problem.
A popped, bulged, or leaking cap must be replaced.
I use a Hakko 936 regulated soldering station. Mine was under $80 USD.
Very nice unit, very well made.
I use the 2.5mm chisel tip for computer board cap replacements.
- Scott Brochu
Re: DCX Woes
It's not bulged that I can see.bgavin wrote:A leaning cap is not a problem.
but do you see the missing wire? WTF never seen this......but I never usually open electrical devices either.
So heating the underside of this board with my 50 watt iron and try shoving a wire through the back and touching the other still there coming out the cap is not a good idea?
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: DCX Woes
It might be worth a shot, but I get nervous about soldering that far up on the lead wire for a capacitor. If it were me I'd find a suitable replacement cap and replace the one there with it.Scott Brochu wrote: So heating the underside of this board with my 50 watt iron and try shoving a wire through the back and touching the other still there coming out the cap is not a good idea?
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
4 DR250s
2 ATs
Re: DCX Woes
That's definitely not a cap. It looks to me more like an Rod-type inductor sealed in shrink tubing. How does the soldering pad look on the other side of the board? How about its sibling just behind it, are both its leads intact? Is there evidence of arcing (carbon or metallic traces)?
Re: DCX Woes
+1. I'd put a piece of resistor or capacitor lead through the hole, long enough to reach the nub, and solder it up. Then I'd put a couple of globs of silicone sealant between the coil and the caps on either side of it to stabilize it.Radian wrote:That's definitely not a cap. It looks to me more like an Rod-type inductor sealed in shrink tubing.
- Scott Brochu
Re: DCX Woes
Doesn't seem to be any indication there was any arcing or scoring.
I think I should just replace it. But how do I go about finding a replacment of the same thing?
- Zack Brock
Re: DCX Woes
If it is a rod inductor as it appears to be, it can take the heat of resoldering it that close. The rubber might get a little hot but I wouldn't worry about that. The rod inductor is just a coil of wire essentially. I would just resolder and not replace. If you are really worried about the heat, you could take a little metal alligator clip if you have one available and attach it to it to act as a heatsink while you solder.
Zack Brock
Re: DCX Woes
De-solder the circled piece and insert a longer piece of wire that will reach the bottom of inductor. Solder to the board, solder the 2 ends together, and test.
And +1 to Bill's comment about silicone to brace it in.
- Scott Brochu
Re: DCX Woes
Your saying to go ahead and make a small hole from the other side and to heat, apply solder when the little bit of metal that is still sticking out of the inductor and meld them together with a gob of solder. Between the new metal (?) and the little piece?Zack Brock wrote:If it is a rod inductor as it appears to be, it can take the heat of resoldering it that close. The rubber might get a little hot but I wouldn't worry about that. The rod inductor is just a coil of wire essentially. I would just resolder and not replace. If you are really worried about the heat, you could take a little metal alligator clip if you have one available and attach it to it to act as a heatsink while you solder.
and attach the clip to what the rubber part of the inductor or try to wedge it in the 1/4" space I will have and attach it to the metal bottom of the good one?
- Scott Brochu
Re: DCX Woes
What kind of wire? copper?DJPhatman wrote:De-solder the circled piece and insert a longer piece of wire that will reach the bottom of inductor. Solder to the board, solder the 2 ends together, and test.
If this works I...I...I will pick up a bass guitar......BUT just hold it!
- Zack Brock
Re: DCX Woes
LOL!
You can use any old wire, solid core is preferred.
And if you have a vice you could hold it with that rather than have to use your hands.
If you really want to, you could ship it to me, I'll do it for you and ship it back (just that board)
Zack Brock
- Scott Brochu
Re: DCX Woes
Thank you!Zack Brock wrote:LOL!
I do have the vice and clips and I have an iron that has a point but might need to clean it, it has a little oxidizing on the tip.
I'll give it a go, but not tonight.
Gregory East
Re: DCX Woes
Putting all the good advice together I get this:
Unsolder the good connection from the board so you can solder your extension wire to the component with room to move (and wave the iron around without accidentally melting something else). Then replace the component in the board.
Spare hands are useful.
- BrentEvans
Re: DCX Woes
