pole mounts for t39?
eburg
#1 Post by eburg »
I'm getting ready to build a couple t39's, I've read the plans (will be doing it again a few more times) but looking at the layouts I was trying to figure out where I could install a pole mount in without interferring with the efficiency of the cabinet, or interferng with the cabinet top panel or interior baffles?
Re: pole mounts for t39?
#2 Post by DJPhatman »
Builder Tim A built a 20" wide T39 with a pole mount in the driver access door. As long as it is air-tight, it will not interfere with the sound, no matter where you put it. Just decide if you will use the T39 standing up or laying down.
#3 Post by Bill Fitzmaurice »
eburg wrote:I was trying to figure out where I could install a pole mount
Why pole mounts? If your intent is to put your subs on either side of the stage and not wall load them you need to read the FAQs.
eburg
#4 Post by eburg »
Sometimes, I have very limited space, so I am just trying to plan ahead
