+1jcmbowman wrote:... If you're DJing yourself, I agree that there's no need to compress the material. But if you're doing sound reinforcement for other DJs, it's imperative to have a limiter in place. The amount of gain that can be added on a typical DJ mixer is downright ridiculous.
...thankfully when I do rent/loan the system out, I go with it. If someone else is using the rig that night I'll initially set the gain structure with the faders on the mixer maxed out just in case.
And I might add to other DJ's using Serato to watch the Master gain and Track gains as well. Serato allows you to adjust the master gain as well as the gain for each song (track) individually to compensate for a low signal level. I caught a DJ the other night on Serato with the track gains fully in the red and completely unaware of the distortion...That's when the limiter on the DRPA is handy. Still sounds like crap but at least the speakers are protected...
