jcmbowman wrote:+100!LelandCrooks wrote:Epoxy, epoxy, epoxy. I used gorilla glue twice on other projects. I think it's worthless. 5 minute epoxy on tee nuts, on the barrel and washer part. Pull up snug. Let dry for 10 or 15 minutes, run a tap. Never fails. You have to tear the top ply where the washer is glued and the internal bond to break it loose. I can pull with a 3/8 ratchet with a hex driver, hard, and they never budge.
Cut the tee nut out. Install a new one using EPOXY.
Out of the 120+ hurricane nuts I've installed so far I've managed to spin about 15 of them. The worst was the access cover that had 2 spin when I was trying to take it off..... but that's another story. I had some 5-minute epoxy laying around about a month ago when I was trying to fix another one and I figured what's the worst that could happen? Since then I've never had a problem. And if any of the old ones get loose - I'll just epoxy them. problem solved.
This is what you guys are talking about , correct?
http://loctiteproducts.com/products/det ... 9&plid=759
