Glad you posted that. Got my order in for some Beta 8a's!LelandCrooks wrote:Shipping will be closed Jan 8th through Jan 18th. I'm going to NAMM, and there won't be anybody else available to box and ship stuff.
Speakerhardware.com
- jswingchun
Re: Speakerhardware.com
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Displaying or attending?I'm going to NAMM, and there won't be anybody else available to box and ship stuff.
Attending. Only my second one. Thinking about displaying at some point in the future.
Gregory East
Any idea when the jack throat fillers will be back in stock?
I have all the fillers. Which item are you looking at? I thought I removed all the out of stock text.
found it.
New stuff.
Good quality cables. Not chinese imports, well made. Speakon speaker cables and XLR microphone cables.
http://www.speakerhardware.com/products.php?cat=124
GRR-Rippers. I love these things.
http://www.speakerhardware.com/micro_ji ... GR200b.php
Finally a metal corner that works well on 1/2.
http://www.speakerhardware.com/metal_ca ... wc1824.php
That looks like a nice finger saver to me.LelandCrooks wrote:GRR-Rippers.
Nice, I like the looks of these corners. Makes for a slightly better tetris factor compared to plastic chevron corners. What radius router bit would work for these corners?Finally a metal corner that works well on 1/2.
Edit: never mind, I should have clicked the link and read: "Use a 1/2 radius round over router bit for the best fit."
Mark Coward
Nice, would you be able to carry the ZeroPlay guide bars? Those look nifty.
Mark Coward
I had not seen those. I'll order one and take a look. Pretty cool.
GekoMusic94
Can i order from italy?
Have:
2x FBT Jolly8ra (active)speakers (100-20.000Hz)
1x Voice System SUB VS8 (active)subwoofer (55-100Hz)
1x MTH-30 (RCF LF12G301)
You may for everything except Eminence. For overseas ordering of Eminence you must use a mailing house as explained here:GekoMusic94 wrote:Can i order from italy?
http://billfitzmaurice.info/forum/viewt ... =14&t=9905
Turntablist
Paint, glue, adhesives and similar hazzardous stuff can't be shipped over the atlantic either as I've understood it.Bill Fitzmaurice wrote:You may for everything except Eminence.GekoMusic94 wrote:Can i order from italy?
-2 T48 3015LF
-2 DR250 2510 crossfired
Turntablist wrote:Paint, glue, adhesives and similar hazzardous stuff can't be shipped over the atlantic either as I've understood it.Bill Fitzmaurice wrote:You may for everything except Eminence.GekoMusic94 wrote:Can i order from italy?
That depends on the Transportation of Dangerous Goods act (TDG). If it is a consumer product it should be able to be shipped, sometime it depends on the quantities.
The abs glue is a big no no. I can't even mail it in the US. It has to go Fedex. PL, I have discovered can go.
