Xti-1000 is it good for a Table Tuba or 2?
I did ask this on the home theater area but I think this may be a better area to ask, I want to know if I use an HT receiver for all other channels and the xti-1000 for a pair of Table Tubas if this would work using the dsp as the x-over and would it be a good way of powering/integrating them into the HT system?
Re: Xti-1000 is it good for a Table Tuba or 2?
I'm sure some other, far better qualified folks will chime in here - but in my experience, most home theatre units have a single RCA for the subwoofer, which is already crossed over. An XTi 1 would be fine to power any Tuba, but it's probably overkill. Your sub(s) will go WAY louder than the rest of your system.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
It would cost me more for 2 plate amps or about the same as 1 xti-1000 to power 2 dual loaded TT's I just don't know about the integration of the xti and a HT receiver?
- David Carter
I know almost nothing about home theater, but if the above statement is true, you may want to check out a QSC GX3 amp. I believe they have RCA inputs on the back, and they are $299 new (Musician's Friend has a factory restock for $249 right now). I personally don't have any experience with the GX line from QSC, but I loved the PLX2 series amp I used to have.bzb wrote:most home theatre units have a single RCA for the subwoofer
Dave
- 2 x Titan 39 (BP102 - 14"W)
