Tammojsmit ask me to post how I did the acid etching on the effects pedal boxes like this.
Instead of posting how I did it, here is a link to a tutorial.
http://www.aronnelson.com/gallery/main. ... y/album24/
I used glossy inkjet photo paper printed on a laser printer instead of the PnP in the tutorial above. Here are a couple of links about using photo paper. They reference making circuit boards, but the concept is the same on boxes.
http://modman.blogdrive.com/archive/20.html
http://modman.blogdrive.com/archive/30.html
I also used muriatic acid mixed with peroxide to etch instead of what was used in the tutorial. I don't recall the exact mix of the two, it's been a while. It's dangerous stuff!! Use it outside and wear proper protection!!
I would suggest you can search around on diystompboxes.com for more detailed information if you decide to take this project on.
I can try to answer questions about this, but I have only done it a couple of times on boxes along with a couple of PCBs.
PS - I never thought of this before, but a guy could make pretty cool badges for cabs with this technique...
