Eight DR 200's w/scaffold
DJ Scotty G
#1 Post by DJ Scotty G »
Hello, Here are my DR 200's out for the first time this year with my new scaffold. This was a school dance with about 1000 kids. The sheriff was getting calls from home owners about 1 1/2 miles away about loud music. :D I love my DR200 these little boxes rock. Here are some pics:
http://i390.photobucket.com/albums/oo34 ... ure001.jpg
http://i390.photobucket.com/albums/oo34 ... ure002.jpg
http://i390.photobucket.com/albums/oo34 ... ure003.jpg
http://i390.photobucket.com/albums/oo34 ... ure004.jpg
http://i390.photobucket.com/albums/oo34 ... ure006.jpg
Cheers, Scotty G
SoundInMotionDJ
Re: Eight DR 200's w/scaffold
#2 Post by SoundInMotionDJ »
Are the bottom two DR's built as a single cabinet?
10 T39S + 10 DR200 + 1 T48
James R
#3 Post by James R »
Nice 8) what's the silver junction box in the last photo
4 x T48 24.5" 3015LF
8 x 112 Otops
NEXT 2 x DR280's
DJ Scotty G
#4 Post by DJ Scotty G »
SoundInMotionDJ wrote:Are the bottom two DR's built as a single cabinet?
Yes they are. I built them as single cabs and then wrapped them in 1/4 ply to make them one cabinet. They are a little heavy being made from 1/2" BB and then wrapped with the 1/4".
James R wrote:Nice 8) what's the silver junction box in the last photo
That is my speaker distro boxes. I run a 4-wire cable out to the DR200's and they hook into that box. It has speakons in it to get to the DR like this:
Each side:
2 wires from QSC RMX 2450 to (2) DR's.
2 wires from QSC RMX 1850 to (2) DR's.
each side of the amp has a 4 ohm load, because I run stereo. Plus this way I have only one speaker cable going to each stack, less wire and looks better than tons of different cables going to the speakers. I should post some pics of the cables, because others may want to do the same.
James R
#5 Post by James R »
Very good idea
8 x 112 Otops
NEXT 2 x DR280's
Mark Coward
#6 Post by Mark Coward »
Nice setup, that does seem like a lot of juice for the 8" drivers in the DR200's. And....when are you going to upgrade to BFM subs?
Mark Coward
Dave Non-Zero
#7 Post by Dave Non-Zero »
Each side:
Why dont you just have a 4 core cable that you split into pairs with two speakons on each end? it would save you a few of the speakon cables and look even neater...
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
bgavin
#8 Post by bgavin »
I use the two-pair wiring in my Speakon cables. Lows get #1, Highs get #2 pair. A single cable daisy chains from box to box. I do not have the High boxes switchable, so I built a few #1 to #2 cross-wire adapters when needed.
DJ Scotty G
#9 Post by DJ Scotty G »
I have not had any issues with my 8's with the QSC amps. I have a DBX Drive Rack and I have limits set for the Dr's and my subs.
I have one 30" wide Titan 48 built and I have not had time to build the other three yet, I just moved and I have lots of other projects now w/the new house. I will use 4 30" Titan 48 3015LF cabs with my DJ rig.
DJ Pyro
#10 Post by DJ Pyro »
did you ever get pics of the box?
DJ Pyro
"Mr. Set It On Fire"
