Baltic birch warping
vlad335
#1 Post by vlad335 »
I cut out the 2 sides for the titan from BB last night and they began warping immediately. The original 5x5 sheet was straight BTW.
(Excuse the crappy pic. It's actually worse than the pic shows.)
The scrap pieces left over are really warped. Inversely, I have two 8' x 23 7/8" pieces of Lowes "Blondwood" for the interior panels that are straight as an arrow.
I clamped it down to my workbench over night laying across a board and it just sprang right back.
Anyone else have this problem with BB? Can I fix it somehow or just leave it and hope the interior panels will straighten it out?
Currently running:
Four Titan 48's, Six Omnitop 12's, Two Wedgehorn 10's, Omni12 2-10
Also Built: Omni15 Tallboy, Omni10.5.
'The hardest material on earth is the human skull'. How do we know this? Try pounding a new idea into one.
Mikey
#2 Post by Mikey »
vlad335 wrote:I clamped it down to my workbench over night laying across a board and it just sprang right back.
Can I ... just leave it and hope the interior panels will straighten it out?
It seems odd that the full sheet was fine but then warped when you cut it, but perhaps the wood wasn't dry enough when they made the plywood. Fresh cuts then allowed the moisture content to leave more easily and rapidly.
Since you already tried flattening it, it's not likely that installing it in the cabinet will flatten it, either. Besides, if you used it the way it is and then it DID happen to flatten-out in the cabinet, the result might be further problems (air leaks).
vlad335 wrote:Can I fix it somehow
If it is likely to go to waste otherwise, you can try getting it wet (not saturated), and then clamp and weight it for several days. Rehydrating the wood and then forcing it to dry flat is likely to work. This is the method used to bend plywood, so it should work to flatten it also.
#3 Post by Bill Fitzmaurice »
Don't worry about it, so long as you square everything up during the build process it will be fine. The hardest thing to deal with is being sure the cuts are straight.
Les Webb
#4 Post by Les Webb »
Bill Fitzmaurice wrote:Don't worry about it, so long as you square everything up during the build process it will be fine. The hardest thing to deal with is being sure the cuts are straight.
+1
It gets difficult to cut angles and miters on warped wood, otherwise the horn plates will pull it square when you screw them in.
Les
Tim A
#5 Post by Tim A »
Use it, it's fine. You'll need to be carefull when flushing them up, that's all.
vlad335
#6 Post by vlad335 »
Cool. Thanks gentleman. I figured that the panels would pull the side in. I just freakin worry too much sometimes.
I just cut out the round baffle for the 15 so it's almost time to start glueing and screwing.
What part of the Titan build do you guys dislike the most? I hate cutting the baffle/panel 2, drilling holes/inserting the hurricane nuts, and getting the driver to fit right. ( Where I am now...)
Currently running:
Les Webb
#7 Post by Les Webb »
Installing the driver. By far the most aggravating part for me. Second place goes to cutting braces.
Les
Tim A
#8 Post by Tim A »
Les
Braces are number one for me. I hate them almost as much as cutting and gluing piezos!
I always test fit the driver to the baffle after the nuts are installed. It makes life a lot easier whn you go to install it. So do flexible shafts for your screw gun.
Les Webb
#9 Post by Les Webb »
Tim Ard wrote:I hate them almost as much as cutting and gluing piezos!
Ha! Strangely enough I enjoy cutting and gluing piezos 8)
You mean sniffing the glue. :shock:
Les Webb
#11 Post by Les Webb »
I"ve been told I should just "STOP IT!" It started with permanent markers :D
Watch it here:
http://youtube.com/watch?v=HYDwvS9nPCk
vlad335
#12 Post by vlad335 »
I like to cut and glue the piezos too.
LOL. Now I know why. :D
Currently running:
#13 Post by LelandCrooks »
SWMBO says the guy's a wimp. He should be sniffing the GREAT BIG black markers. They rule.
:lol:
Marko Ursin
#14 Post by Marko Ursin »
[quote="Mikey]It seems odd that the full sheet was fine but then warped when you cut it, but perhaps the wood wasn't dry enough when they made the plywood. Fresh cuts then allowed the moisture content to leave more easily and rapidly.[/quote]
Plywood is not made from dried wood. It's made of green wood and dried during gluing process. I've yet to find a perfectly flat bb plywood and I've seen quite a lot of them.
Marko
vlad335
#15 Post by vlad335 »
I hear what you are saying but the 5x5 piece was pretty straight until it was ripped. I know because I looked down the sides when I was at the wood dealer.
I know for a fact that it warped after it was cut down. I cut the sheet in half at 30" then ripped each piece to 24". The 6" leftovers are even more bowed than the wood I used for the sides of the Titan.
Since I never saw anyone post any mention of BB warping after being ripped I'm going to chalk this up as a weird anomoly. I guy that sold me this stuff is definetly going to hear about it on Monday.
Currently running:
