I'm dithering on building a more compact rig. Considering to start build a pair of T24s and use my Simplex 12 wedges, which sound decent, as tops. Or maybe build a pair of SLA Pros for tops. Or just the T24s them with my OT12s (they sound SO GOOD!) and truth be told I can probably squeeze a pair of OT12s in a lot gigs but I need a smaller sub setup.
Ok that's the background, here's the actual question.
Apologies up front if this has been answered elsewhere. I have searched and read posts that do partially address the questions I'm investigating. For example I do know two single loaded cabs is better than one dual loaded cab in general. Also wider is always better single or dual but I want to stick to a 24" footprint.
I'm looking at the SSF102.50L and the 11.5mm Xmax is nearly twice the other drivers recommended. This is probably a terrible over simplification but wouldn't that additional displacement in a single loaded cab roughly be like having a dual loaded cab with a driver like the BP102 with 6.5mm Xmax?
If I'm not way off mark there then would a single loaded SSF102 have a SPL chart comparable to the chart I was able to find for 24 inch wide T24, loaded with two S2010 or two BP102?
Thanks for any help and feel free to
Dave
