TLAH tight space
Posted: Fri Jan 16, 2026 12:49 am
by tfoust
For those that have built the TLAH triangle config how did you manage to put mounting screws inside next to the side panel? Before you tell me to mount the drivers on the front of the baffle the recommended driver (I bought) is designed to mount on the back. The edge of the cone is meant to be held secure by the pressure of the frame pressed against the back of the baffle. It’s going to be a trick getting screws inside the space between the driver and the side panel.
Re: TLAH tight space
Posted: Fri Jan 16, 2026 7:53 am
What driver is that? Pretty much every driver made today will mount from the front or back. Drivers don't rely on pressure of the frame against the baffle to hold the cone in place, that's accomplished by the surround and spider.
Posted: Fri Jan 16, 2026 10:49 pm
by tfoust
Goldwood Sound GW-4028/S
Posted: Fri Jan 16, 2026 11:04 pm
That can be front mounted.
Posted: Sat Jan 17, 2026 6:50 am
by tfoust
OK, thanks.
Posted: Sun Jan 18, 2026 2:53 pm
by jimbo7
I plan on making my triangle TLAH's soon. Are you documenting the build?
Posted: Mon Apr 20, 2026 1:40 am
by tfoust
No
Posted: Mon Apr 20, 2026 2:12 am
by tfoust
I will entertain questions though
Posted: Mon Apr 20, 2026 9:35 pm
tfoust wrote: ↑Mon Apr 20, 2026 2:12 am
Hah! Okay! How is the build coming along?
Posted: Tue Apr 21, 2026 10:05 am
by shawn_g
What's your favorite food?
I'll see myself out.
Posted: Sat Apr 25, 2026 6:31 am
by tfoust
In suspension just now. Work got in the way. I have both units built to the point of attaching back panel. The first one is wired. Have yet to wire the second. Filters are made. Should be back at it in the next week.
