RCF L15s801 for the T48?
tribal king
#1 Post by tribal king »
Hey guys! Long time no type. Hope all is well in your respective neighborhoods...
As the header says, is the RCF L15s801 Subwoofer a good candidate for the BFM T48? Specs are as follows.
Fs: 48Hz
Qts: .32
Xmax: 6mm
Re: RCF L15s801 for the T48?
#2 Post by Bruce Weldy »
tribal king wrote: Sun Dec 07, 2025 2:31 pm Hey guys! Long time no type. Hope all is well in your respective neighborhoods...
Fs: 48Hz
Qts: .32
Xmax: 6mm
Nope....not enough xmax if you want to give it some power.
tribal king
#3 Post by tribal king »
Bruce Weldy wrote: Sun Dec 07, 2025 7:20 pm
Fs: 48Hz
Qts: .32
Xmax: 6mm
Ok what about the PRV 15w1000v2 specs?
Fs: 39Hz
Qts: .68
Xmax: 6.37
#4 Post by Bruce Weldy »
tribal king wrote: Mon Dec 08, 2025 7:21 am Ok what about the PRV 15w1000v2 specs?
Fs: 39Hz
Qts: .68
Xmax: 6.37
The recommended drivers in the plans are at 9.6 (Emimence 3012LF)and 11.8 (Lab 15) xmax. I didn't check to see if the other parameters match. Do you have the plans? It has all of the T/S parameter specs and ranges.
Rich4349
#5 Post by Rich4349 »
"Ok what about the PRV 15w1000v2 specs?"
If you want big bang for your buck this is the PRV most in here refer to:
https://www.parts-express.com/PRV-Audio ... quantity=1
