SB 15SW800s into T48
Keryn O'Shea
#1 Post by Keryn O'Shea »
Good evening lads,
After finding a suitable 15" driver available locally to replace the 3015CXs in two of six T48s, the SB Audience Rosso-15SW800
https://www.sbaudience.com/index.php/pr ... o-15sw800/
Which is has 11.28 Xmax with an 800w AES rating
l've now confused myself on Xmax/AES and vlimits
Using the plans guide for vlimit for a 15" with 11.28mm Xmax, we're at 60v, though the 15NL9300 is mentioned at 80v as it's 800w AES, but with 8mm Xmax.
And then l'm wondering if l fit the pair of 15SW800s, will they need more voltage to deliver their excursion than the 3015LF and LAB15s in the other 4 cabs..? Needing more amp channels & DSP
On one hand my thoughts are, l can fit the pair of 15SW800s and run 60v limit & not miss out on output from those two cabs. The other is replace all 6 drivers and move to 80v limits.
I understand these are maximum limiter settings, real world setup is more conservative.
Re: SB 15SW800s into T48
Personally I wouldn't be mixing drivers, which can result in having to use different EQ and limiting, which can lead to driver killing mistakes. Pick one and stick with it.
Keryn O'Shea
#3 Post by Keryn O'Shea »
Yes, l agree. If l were to change to all 15SW800s, would l set a 60v or 80v limit?
#4 Post by Bill Fitzmaurice »
60v. It's set to the Pe or Xmax limit, whichever is lower.
Keryn O'Shea
#5 Post by Keryn O'Shea »
Ok great, thank you Bill
DOM THE SAUSAGE
#6 Post by DOM THE SAUSAGE »
I run 2 titan 48s with the sb nero 15s wired down to 4ohms at 60v limit and these things shake rafters and windows literally im so glad I made them absolutely beast of subs
DOM THE SAUSAGE
#7 Post by DOM THE SAUSAGE »
