Simplexx 10 Driver
b_ryan
Simplexx 10 Driver
#1 Post by b_ryan »
Hi, driver question for ya'll. I've read the faq but I still had a question regarding these two drivers. Looking at the plans, the beyma seems to match the specs and at $75 it fits my budget too.
Beyma 10CMV2 - https://www.parts-express.com/Beyma-10C ... quantity=1
Thiele-Small Parameters
Resonant Frequency (Fs) 52Hz
DC Resistance (Re) 5.9Ω
Voice Coil Inductance (Le) 0.8mH
Mechanical Q (Qms) 3.8
Electromagnetic Q (Qes) 0.47
Total Q (Qts) 0.42
Compliance Equivalent Volume (Vas) 1.55ft³
Mechanical Compliance of Suspension (Cms) 216mm/N
BL Product (BL) 13.4T·m
Diaphragm Mass Inc. Airload (Mms) 0.042g
Maximum Linear Excursion (Xmax) 6.5mm
Surface Area of Cone (Sd) 0.038cm²
On the other hand this driver seems to fit the specs as well.. except its just shy of the Fs range. It's a small discrepancy, what would the trade off be if used this one. At $40 it's peaked my interest. I know you get what you pay for in these drivers, but if it sounds good...
GRS 10PT-8 10 - https://www.parts-express.com/GRS-10PT- ... quantity=1
Resonant Frequency (Fs) 47Hz
DC Resistance (Re) 7.1Ω
Voice Coil Inductance (Le) 1.6mH
Mechanical Q (Qms) 11.4
Electromagnetic Q (Qes) 0.5
Total Q (Qts) 0.48
Compliance Equivalent Volume (Vas) 1.63ft³
Mechanical Compliance of Suspension (Cms) 0.27mm/N
Diaphragm Mass Inc. Airload (Mms) 43g
Maximum Linear Excursion (Xmax) 6.8mm
Surface Area of Cone (Sd) 348cm²
Thanks for your time
Re: Simplexx 10 Driver
Flip a coin. The GRS looks like a real bargain.
