T39 Alternate driver option?
J_Dunavin
#1 Post by J_Dunavin »
It's been a while since i've posted on here, hope everyone is doing well and is either covered in saw dust and PL or jammin some tunes.
Just wanted to see if this 10" Neo Eminenece driver would work with some slim T39s.
https://www.parts-express.com/Eminence- ... quantity=1
My gut says no as the xmax is only 4.5mm, but all the other specs JUST squeek in there. IF it were expectable, what would be the voltage limit and high pass freq?
My intention would be to build two slims to go with my two 20" wide 39's and two Otop 8s
thanks!
Re: T39 Alternate driver option?
#2 Post by Tom Smit »
Good to see you back.
I don't know what that model is, exactly, so, it is hard to tell. I searched the Eminence site for a 10" like it but couldn't find it. Therefore, I couldn't find the Vd.
Can you swing an extra $25 per cab and get the BP102 instead?
J_Dunavin
#3 Post by J_Dunavin »
Hi Tom!
I had to google it, but you can calculate Vd by multiplying Xmax by SD and I'm only coming up with 155CC for this guy. Unfortunately that's quite a bit less than the BP102, though it is more than the S2010. Might not add up, but it sure looks cool :D
I don't really NEED more cabs, but if the price is right, why not :lol:
#4 Post by Bill Fitzmaurice »
That's a 4 ohm OEM version of the Deltalite II 2510. Good for mains, not for subs.
