Advise needed [T30 alternative speaker option]
mosiah
#1 Post by mosiah »
Would the below mentioned speaker work efficiently in the T30?; And what should the limiter and crossover be set to if using said speakers?
https://prvaudio.com/products/12w800a/? ... u37GfaIhvr
Re: Advise needed [T30 alternative speaker option]
#2 Post by Bruce Weldy »
From their website....
55 to 5,800 Hz frequency response makes this midbass/woofer suitable for two or three-way designs
Wrong tool for the job.
#3 Post by Bill Fitzmaurice »
It can be used as the specs are just within the acceptable range. But with the short xmax it's only going to take 35v/150w. Buy once, cry once.
mosiah
#4 Post by mosiah »
Noted, with thanks
