Page 1 of 3
J15 Build
Posted: Sun May 19, 2024 6:12 pm
by Clef's of Bass
I'm back for another J15 build (woofer only).
I was visiting my local hardwood supplier, and much to my surprise, they had BB ply!
Sourced a fresh new Delta Lite II 2515.
This should be another fun build.
Re: J15 Build
Posted: Sun May 19, 2024 10:12 pm
Re: J15 Build
Posted: Thu May 23, 2024 6:58 pm
by Clef's of Bass
Making some slow progress. Pilot drilled radiuses in the corners, jig saw cut most of the waste, the set up a flush trim router for the rest of it. Clamped the six" diameter plug to the center, followed with the router. Then clamped straight edge across the length then the width of the baffle for all of straight cuts to finish. Getting closer to the glue up!!
Re: J15 Build
Posted: Fri May 24, 2024 6:48 am
by Clef's of Bass
Done with dimensioning pieces. On to the glue up!
Re: J15 Build
Posted: Fri May 24, 2024 7:35 am
Nice work!
Re: J15 Build
Posted: Tue May 28, 2024 8:32 am
by Scott Brochu
Looking clean and nice.
Re: J15 Build
Posted: Tue May 28, 2024 11:15 am
by Seth
Yeah baby! That's looking really clean. Nice job!
Re: J15 Build
Posted: Sat Jun 01, 2024 1:25 pm
by Clef's of Bass
I got a lot of the glue up done for the middle part and have the baffle glued to the bottom. I'm ready for the mouth panels before the top. I'm going to lay it up, clamp, and drill for pilots. Then disassemble, glue, and finish with 1" countersunk #6 screws to hold them tight in place for the PL dwell time. So far, so good
I'm also taping off all of the exterior glue joints to keep the PL off of the panels.
Re: J15 Build
Posted: Sat Jun 01, 2024 9:48 pm
Beauty.
Re: J15 Build
Posted: Sun Jun 02, 2024 3:39 pm
by Clef's of Bass
Really taking shape now!
Almost ready to start on the side.
Re: J15 Build
Posted: Mon Jun 03, 2024 6:32 pm
by Clef's of Bass
Just checked up on it after the PL cured and man, this thing is rock solid!
Re: J15 Build
Posted: Mon Jun 03, 2024 10:39 pm
by Seth
Everything looks surgical and perfect. Really nice job.
Re: J15 Build
Posted: Tue Jun 04, 2024 4:07 am
by Clef's of Bass
Seth wrote: ↑Mon Jun 03, 2024 10:39 pm
Thanks Seth. It's been a really fun build so far.
Re: J15 Build
Posted: Tue Jun 04, 2024 5:50 pm
by Clef's of Bass
Flush cut the mouth panels.
Re: J15 Build
Posted: Tue Jun 04, 2024 8:51 pm
Love that BB ply.....so fun to work with and then look at. Too bad we always end up covering it up.
