Page 1 of 3
Questions for Table Tuba build
Posted: Thu May 09, 2024 9:54 am
by Mr T
Got the plans and am reading it over.
I'm going to use the Dayton Audio LS10-44, cabinet width of 21 inches as suggested.
Main speakers will be pair o klipsch heresy 1.5's room is 11x11x8 (LWH)
1. It looks like 2 4x8 sheets will be more than enough- that sound right?
2. What amp are you running/suggesting?
Re: Questions for Table Tuba build
Posted: Thu May 09, 2024 10:08 am
Which Table Tuba are you building? There's a couple of different models...
Posted: Thu May 09, 2024 10:12 am
You mentioned 4x8 sheets. If you're using Baltic Birch (it's the best), it is typically 5x5. The 5x5 sheets are cheaper per square foot than the 4x8. Use Cutlist software to get the best layout and that will help determine how much plywood you need.
Good to see a fellow Texan here.
Posted: Thu May 09, 2024 10:17 am
by Mr T
I ordered the standard table tuba plan, so this will be the 30x30x21 cabinet.
Posted: Thu May 09, 2024 10:21 am
by Mr T
I found this online, says 4x8, and its only about 30 minutes away.
https://www.plywoodcompany.com/pd/birch ... 0%2A4X8%2A
Thanks for the welcome!
Posted: Thu May 09, 2024 10:27 am
This also have 5x5 at $2.07/sq ft.
https://www.plywoodcompany.com/pd/birch ... m-5x5/464
The 4x8 is $2.62/sq ft.
That said, download Cutlist and put in the dimensions of the pieces. Try with 5x5 and 4x8 material and see which fits better and comes out the cheapest.
Posted: Thu May 09, 2024 10:48 am
Posted: Thu May 09, 2024 11:03 am
by Mr T
Only need one pretty side so even better- cool.
Now- amps...
Posted: Thu May 09, 2024 2:07 pm
by Radian
I’ve got a MiniDSP PWR-ICE running our bedroom system. Either the 125 or 250 is plenty. Spendy and requires a laptop to unlock all the features, but definitely get what ya pay for. That or try surfing FB Marketplace or Craiglist for a used “architectural” install power amp like an Audio Source or Speakercraft.
Posted: Thu May 09, 2024 3:15 pm
Ha! You dug a little deeper than I did.
Posted: Mon May 13, 2024 7:47 am
by Mr T
I was able to get the plate amp for my old velodyne working again over the weekend- its rated 165 RMS/275 peak @ 8 ohms. Enough?
Posted: Mon May 13, 2024 9:03 am
My sub amp is 75w/4 ohms.
Posted: Mon May 13, 2024 1:14 pm
by Mr T
Saves a few bucks then glad to hear it.
Posted: Mon May 13, 2024 2:31 pm
by Mr T
Saves a few bucks then glad to hear it. cant tell from plans but should I use any fill material?
Posted: Mon May 13, 2024 10:49 pm
Mr T wrote: ↑Mon May 13, 2024 2:31 pm
Nope.
