Which Simplex 15 Cab?
Posted: Mon Mar 04, 2024 1:00 am
In the SPL Charts, this can't be accurate for the 15 inch Simplex ported sub? 115 at 40z? Might wanna fix that. . .
This is the heading for the 15 inch sub - The Simplexx 15 Bass cab, BP1525 woofer, Sealed versus Ported Low Frequency Maximum SPL:
Not sure how to copy / paste the graph. It isnt working when I try
I have a 20 inch T39 with the best Eminense neo cone ( whatever was recommended ) and it's larger and louder than I need.
I was told two of the Simplex 15 inch subs is approx equal to my T39. I'd want 2 subs for the rare times we are loud.
For most of my work one 15 inch Simplex cab will do. I never need to push the T39.
I'll be using it as a sub for my small PA mains. I'll use 2 or 4 mid/high boxes each with a 6" Alpha 6A and a 6 tweeter melded array = 3 rows of 2.
Choices are the Bass Cab, the PA Cab or the Pro Sub. For a small PA, which single box is best? I play Dueling Pianos mostly but will also do
Rock and Fusion with synths at times.
I'm thinking any of the 3 versions will be fine but as indicated by the name, the PA or Pro version would be best? Thanks for any advice.
