16 Ohm drivers
Camillo
16 Ohm drivers
#1 Post by Camillo »
I'm thinking about building an OmniTop15 as a basscab but find it hard to get 16 ohm drivers. (for a vox - 65 super bass foundation that requires Minimum 15/16 ohms load.
In The 12" area there are more but i'd like - one-OmniTop 15, not dual 12" or 10".
https://faitalpro.com/en/products/LF_Lo ... =151060101
Seems to work but are there anyone who made this? Do i miss something or is it just to go with a 16o with the same parameters?
There was an eminence with okay parameters except for the xmax that was only 1.6mm...
2x Titan48 26" - Lavoce waf.154.00 & Emin. 3015lf
2x OmniTop15 - Em.Deltalite 2515II- FaitalPro HF107
1x Titan48 "scrappy"- 12" MTX thunder8k car woofer
1x Omni15 TallBoy - 18sound 15g700 Mon. tf0615mr
Re: 16 Ohm drivers
#2 Post by Bruce Weldy »
Camillo wrote: Thu Dec 07, 2023 10:08 am I'm thinking about building an OmniTop15 as a basscab but find it hard to get 16 ohm drivers.
Can't really help you with the 16 ohm drivers, but why an OT15? A Jack 15 would be much better for bass guitar.
Camillo
Re: 16 Ohm drivers
#3 Post by Camillo »
Tru, I looked at it but i have half a ready ot15 already from the top builds i made:) would you think the difference is huge, i watched the chart and combined it with a line from thread that said that below 40hz(isch? ) the electric bass isnt that.. nice.. (dont remember the exact sentence)
But the otop15 runs steady to at least 50-55, right?
Re: 16 Ohm drivers
#4 Post by Bruce Weldy »
Camillo wrote: Thu Dec 07, 2023 11:46 am
Scroll down to the Jack15 vs OT15 comparison....
https://billfitzmaurice.info/forum/view ... hp?t=13636
Re: 16 Ohm drivers
#5 Post by Seth »
The Jack 210 would offer the opportunity to wire in 16Ω.
Camillo
Re: 16 Ohm drivers
#6 Post by Camillo »
I've checked it before i started the thread, but it will be an OmniTop15 since thats what i've started building.
I guess I can use a 16 ohm driver with the same specs? Basscab only, no crossovers that is. Impedance doesnt affect the cab, right? Just double checking🙂
Camillo
Re: 16 Ohm drivers
#7 Post by Camillo »
Seth wrote: Thu Dec 07, 2023 1:03 pm
Oh yes, that looks amazing. And would have been better of course. But if i would have built the jack i would've aimed for the lite version and neo-drivers. Perhaps 2x10s.
But the OmniTop i can use with my main foh ot15s when needed aswell.
Re: 16 Ohm drivers
#8 Post by Seth »
Camillo wrote: Thu Dec 07, 2023 1:12 pm I guess I can use a 16 ohm driver with the same specs... ... Impedance doesnt affect the cab, right?...
As long as the other specs are within tolerance, you're good.
It's mention worthy though, that if there's different versions of the same driver model with different impedances, the driver specs will be slightly different for each impedance version. You can't look at the 8Ω specs, then assume the 4Ω or 16Ω driver of the same model will have the same specs. They wont.
Camillo wrote: Thu Dec 07, 2023 2:27 pm ...the OmniTop i can use with my main foh ot15s when needed aswell.
Ah, I see what you're tying to do now. Interesting. I'll enjoy witnessing it all come together. I'm curious how you'd use a 16Ω cab in a 2 cab array with an 8Ω cab. There's certainly nothing stopping you from just doing it and dialing in whatever the result is. Or, would you switch out the driver in that case? Questioning now... maybe I don't understand what you want to do after all. Hmmmm (strokes chin).
Re: 16 Ohm drivers
#9 Post by Bruce Weldy »
Seth wrote: Thu Dec 07, 2023 3:12 pm Questioning now... maybe I don't understand what you want to do after all. Hmmmm (strokes chin).
He is building a bass rig with and old Vox amp.
Re: 16 Ohm drivers
#10 Post by Seth »
Bruce Weldy wrote: Thu Dec 07, 2023 3:40 pm
Apparently, he wants to also have the ability to incorporate the "bass rig" cab in a line array too. Or, did I misunderstand?
Camillo
Re: 16 Ohm drivers
#11 Post by Camillo »
Haven't thought it all true, in that case maybe 2 cabs in 16 ohms in parallell and The other two in one channel each 8 ohms. Or, i'll just swap driver later on when the vox becomes something to collect dust on a shelf, either way, it feels better to continue with the OmniTop for this. When i arrange music i will use the TallBoy i built, this is for those special Times only 😆 a second stage or so. Either way, i'll be able to the cabinet in the future.
It has a super bass cabinet that originally had an 18", later swapped for a 15" jbl e140 that got messed up in transportation. I Even consider making the otop front and hide it in the vox cab since it is messed up already🤭
Re: 16 Ohm drivers
#12 Post by Bruce Weldy »
Seth wrote: Thu Dec 07, 2023 3:54 pm
I was under the impression that he already had a spare OT15 box from his build.....don't know.
Camillo
Re: 16 Ohm drivers
#13 Post by Camillo »
Bruce Weldy wrote: Thu Dec 07, 2023 3:58 pm
I have some extra left over parts from my last OmniTop build, yes Seth, you understand correctly.
I chose the OmniTop15 to build, and Even if i went with the jack 15 i still would have wondered about the 16ohm and same spec. Thats why i wrote it in the beginning since i understand a 2xanything would make more sence in plot, build, coupling etc. OmniTop is for the future and since i have parts left over from the past. 🙂🙂🙂
Re: 16 Ohm drivers
#14 Post by Seth »
Maybe just use your two tweeterless standard 8Ω OT15's, wired in series, with your bass amp. It's pretty easy to do an outboard series wiring harness.
Camillo
Re: 16 Ohm drivers
#15 Post by Camillo »
Seth wrote: Thu Dec 07, 2023 4:50 pm Maybe just use your two tweeterless standard 8Ω OT15's, wired in series, with your bass amp. It's pretty easy to do an outboard series wiring harness.
Good idea but they will be occupied when that one is used. I know there are better ways, cabs and so on. Right now i use 2x12 but only to test it but since i didnt want to modify the cab i took an old car cabinet, cut it diagonally, inserted two twelwes in each baffle and put it in the hole of where the 18" used to sit. The angle of the drivers playing towards each other, cross-firing i guess, made it obvious there was no high freq in front of the cab but well 45 degree on each side😆
The pressure in the cab was huge, i guess those drivers perhaps needed more space or so🤷‍♂️😌
drivers located inside the v, seen from top [< 🎶
Probably stupid but took 30 minutes 😜
Anyways, thanks for the response, i'll check the 15" 16ohms again to see if i find any.
