Audio interface as a simple dj mixer?
Lesknow
#1 Post by Lesknow »
Heynow! I find myself shopping for both a recording interface and a two channel mixer at the same time. I've looked for answers elsewhere but none of them match up exactly & this forum has always had my back :cowboy:
The only thing I'd use a mixer for is for music playback from laptops & phones into a driverack - amp - OT8/T39 setup. DJ mixers have way more features than I need & I'm thinking I can use the interface for both projects. So at the moment I'm looking at either the SSL2 or the UA Volt 2. A 3.5mm output will apparently put out more voltage than mic level signals & each of the two combination input channels would have a gain adjustment to match outputs on the fly...to me it'd be the same as plugging in a phone to listen through powered monitors like I always do, with the ability to switch between two similar sources. Cha think, can I save a hundred bucks?
Tx!
Rob
And everything is to the back with a little slack
2x 3012HO Jacks for bass
Autotuba
Lesknow
Re: Audio interface as a simple dj mixer?
#2 Post by Lesknow »
I do love the form of the SSL2, with everything on top.
Autotuba
#3 Post by Bruce Weldy »
Lesknow wrote: Tue Jul 11, 2023 2:56 pm I do love the form of the SSL2, with everything on top.
Do you have a link or a brand name to go with the model numbers?
#4 Post by Bruce Weldy »
Nevermind.....I found 'em.
Either one should be fine. Just be sure that you use TRS/TRS or TRS/XLR for connecting to the Driverack.
Lesknow
#5 Post by Lesknow »
Absolutely. Thanks a ton :hyper:
Autotuba
#6 Post by Seth »
Lesknow wrote: Tue Jul 11, 2023 2:50 pm Cha think, can I save a hundred bucks?
Is this the question? When I look them up, they seem to be comparably priced.
What do you intend to record?
#7 Post by Bruce Weldy »
Seth wrote: Tue Jul 11, 2023 6:01 pm
I think he means saving a hundred by using one of these two vs. a DJ controller...
#8 Post by Seth »
Bruce Weldy wrote: Wed Jul 12, 2023 8:12 am
Ah, yeah... I see it now. Your level of comprehension has been off the charts lately. Send me some of whatever vitamin and supplement regimen you've been following.
#9 Post by Bruce Weldy »
Seth wrote: Wed Jul 12, 2023 10:07 am
Ha....no, I thought the same thing you did when I looked up the two devices.....
No vitamin will do it, just many decades of deciphering what people mean, not necessarily what they say. :mrgreen:
