SOLD - Gave It Away - Hammond Eleganti Organ
Posted: Fri Jun 23, 2023 10:42 pm
by biodad
Jazz, anyone?
Make Offer. Located in Ottertail, MN, zip code 56571
If you can get here and want to fix this so it doesnt have the 60 cycle hum, I have schematics, I'll pay cash and I'd keep this organ but that is a long shot . . .
Organ has a 60 cycle hum when one finger tab is enabled to sound. People on the Organ Forum under the "Hammond" catagory suggest it is a ribbon strip needing sprayed clean or it could be a connection going to the amp. There are 3 amps in this organ but I am not one to check this stuff out. Getting at the contacts and connectors is not real difficult.
There are the double sets of draw bars per keyboard as on a B3 or C3, plus finger tabs. There is a built in leslie speaker. It also has the bottom octave (octave 1 of 6) reverse colored keys which select drawbar set #1 or #2 for each keyboard plus 9 other standard B3 presets and the "Cancel" key.
The Eleganti has extra sounds from two other sections such as 3 octaves of strings per keyboard with their own volume and sustain level slider, plus 7 other additional sounds as "On/Off Tabs.
One bass pedal needs a contact which is cheap to buy on Ebay and is a "Z" shaped piece of metal that simply screws onto the end of the bass pedal. No internal assembly needed. It will take you 30 seconds to replace.
