Truck tuba driver.
Posted: Mon May 15, 2023 4:47 pm
by Adrianmest
Hello to you all!
I got some 10" drivers laying dormant. Have had them for years but never gotten around using them. They are car subwoofer drivers.
When looking at the drivers ts parameters compared to the recomended ts parameters in the trt plans, i can see VAS is a bit high at 46,4 and FS low at 26,4.
QTS 0,33
250W RMS
Xmax- unknown (guessing 12-14mm)
Can someone please give their thoughts on using them in a trt or perhaps a TT?
Built 2x TT 16" wide with the recomended dayton 8" that i love. Now it's time for some car audio upgrading next.
Best regads!
Re: Truck tuba driver.
Posted: Mon May 15, 2023 5:54 pm
by Grant Bunter
Not knowing Xmax makes it a guess.
What's the driver, and how deep is it?
Posted: Tue May 16, 2023 12:54 am
by Adrianmest
Posted: Tue May 16, 2023 1:10 am
by Grant Bunter
Good grief, even clicking specs tells us nothing more than what you put up earlier.
If it's more than 5" deep, it won't fit in a truck tuba.
Perhaps it's not ideal, but if it's less than 5" deep, the worst thing that could happen would be to blow the driver (and you're prepared to allow for that)...
For the ?table tuba when you say TT, I would stick to a recommended driver...
Posted: Tue May 16, 2023 1:41 am
by Adrianmest
I couldn't find the depth. From what i can remember they aren't that deep. I already cut the wood for the trt
Making the panels 9" so mounting depth should not be an issue.
Also got the dayton um 10-22 on hand, but it seems a bit like overkill for a trt?
Posted: Tue May 16, 2023 2:20 am
by Adrianmest
I wonder what characteristics fs and vas affects i a horn. Drivers has gotten more expensive these days. Especially when importing to Norway. Thanks for yor swift reply, Grant.
Posted: Tue May 16, 2023 8:11 am
by Adrianmest
By the way, any thoughts on using one of my TT's in the car?
Posted: Tue May 16, 2023 8:44 am
Music doesn't go low enough to justify a TT, especially when cabin gain is taken into account.
Posted: Tue May 16, 2023 10:39 am
by Seth
Grant Bunter wrote: ↑Tue May 16, 2023 1:10 am
Truck Tuba has the driver on the "side" of the cab. Increasing cab width also increases allowable driver mounting depth.
Posted: Tue May 16, 2023 12:10 pm
by Adrianmest
Ok. I understand. But other than the unnecessary extention of the TT, it should be ok? I have dsp as well.
Wath about the GAZ drivers? Just discard them?
Once you go BFM or (horn loaded) you dont go back.
Wath would be the downsides of using them in a trt or perhaps a TT?
Thanks for replying guyes
- Just trying to understand this and save som money potentially.
Posted: Tue May 16, 2023 12:38 pm
Using a Table Tuba in a car would waste space going lower than you have any use for. It's like driving a two ton pickup when you never haul anything more than two bags of groceries. But there's many who do just that.
As for those drivers, I can't recommend anything that doesn't have full specs. Since you already have them I see no reason not to try them.
Posted: Tue May 16, 2023 2:39 pm
by Adrianmest
Thanks. I most certainly will use them for som other duties, or get rid of them!
Posted: Tue May 16, 2023 3:26 pm
by Grant Bunter
Seth wrote: ↑Tue May 16, 2023 10:39 am
Good catch Seth,
My bad..
Posted: Wed May 17, 2023 8:45 am
by Adrianmest
Posted: Fri May 19, 2023 9:35 am
by Rich4349
Not a ton of info, but:
Fs(Hz)
26.4
Vas(l)
46.4
Qts
0.33
Re(Ohm)
3.2
Max Power(W.)
500
RMS Power(W.)
250
Number of Coils
1
Impedance Z-Nom(Ohm)
4
Reference efficiency η0(%)
0.09
Sensitivity(dB) 1-W
81.6
Sensitivity(dB) 2.8-V
85.6
https://speakerboxlite.com/subwoofers/g ... ifications
