Qts and 80hz peak
Posted: Tue May 02, 2023 7:12 am
I have an Eminence custom driver (H&K QS 115 woofer) that I'd like to build a Simplexx cab for, basically because it's simple. I have also been considering a Jack cab. I have attached the provided TS specs. Given the Qts of 0.49, from Bill's excellent build intructions and from modelling, I should expect an approximately +3dB rise at around 80Hz. Besides using a different driver, with a low Qts, is there anyway to mitigate this effect? Would a Jack cab by design not have this 80Hz bump? Would it have other issues? Thanks for any help you all can provide me with.
