				How much Duratex for 2 Jack 12 Lites
				Posted: Thu Oct 27, 2022 11:35 am
				by fender3x
				I have done three cabs with Duratex using roller, but it's been a while, and I can't remember how much I needed. I'll be using the roller again on the two J12L's that I am building. Any idea how much Duratex I'll need?
				Re: How much Duratex for 2 Jack 12 Lites
				Posted: Thu Oct 27, 2022 4:21 pm
				by Grant Bunter
				Buy a gallon, touch up your other cabs while you're at it and have plenty to spare for next time.
Especially if you "prime" with a couple of coats of flat black...
				Posted: Thu Oct 27, 2022 6:37 pm
				by fender3x
				Yeah, I am sure that a gallon will be enough. I live about 20 min. from the distributor, and just over an hour from where they make it so at least I'll avoid shipping. At the cost of a quart, you are probably right that I should get a gallon and find something to do with the excess.
				Posted: Thu Oct 27, 2022 9:32 pm
				fender3x wrote: ↑Thu Oct 27, 2022 6:37 pm
Get a gallon.....it will do a bunch of cabs and it last forever.   I've done probably 10 boxes, cases etc. and I still have a little left out of my second gallon.  Put a piece of plastic food wrap right on top of the duratex and push it down before you put the lid back on when you're done.....I've stored it like that for a couple of years and it won't dry out at all.
				Posted: Thu Oct 27, 2022 11:46 pm
				by Seth
				Bruce Weldy wrote: ↑Thu Oct 27, 2022 9:32 pm
I gotta remember this tip.  I popped mine open after a year or so, to do some touch ups and fill in some dings and scratches.  It was a firm lumpy texture in a thinner liquid.  I stirred it the best I could.  Really could have used a potato masher.  Seemed to do what I need it to do, but still... it wasn't too encouraging.  Gotta try the plastic wrap trick next time around. Thanks Bruce!
				Posted: Fri Oct 28, 2022 6:54 am
				by 9830Lark
				One pint covered a Jack Lite 10 for me.  Two coats with just a tad left over.  Now, I had thoroughly primed with black spray paint first.  So, three pints might just do it.  Two quarts would give you some leeway.
				Posted: Fri Oct 28, 2022 6:45 pm
				by fender3x
				9830Lark wrote: ↑Fri Oct 28, 2022 6:54 am
...and two quarts is as expensive (or a bit more perhaps) than a gallon... So it seems we have consensus.
I too, am going to remember the plastic food wrap trick, since I should end up with most of the gallon left. Thanks, all!
