Cab Design Concept
Posted: Thu Apr 28, 2022 10:12 am
Hello there--
I just joined this forum in the hope of getting some feedback, ideas and hopefully some leads on builders for a cab design concept.
I'm not a builder at all, just a musician who comes up with ideas and gets people to realize them.
Where I am located in Lansing, MI, I don't have anyone currently available who has experience in this field.
I am a solo acoustic performer but also perform with ensembles of diverse instrumentation and volume requirements(acoustic/world/classical/jazz/fusion). I have a fairly simple cab/ext speaker design idea partially inspired by my experience using different amps over the years: Aspen Pittman Spacestation, Bose L1, Acoustic Image, and a fascination with the concept of Johnny Smith's Fountain of Sound amp and Andrew Bird's horn speakers. Although this isn't any of those, it takes inspiration from that.
I need someone to consult with my idea and wondered if I could get your opinions on this--
I try to keep the amount of gear I bring to a gig as minimal as possible (I don't run an entire PA, happy with my Bose L1 model II and Compact for form factor, but in varying ensemble contexts and venues need different projection arrays). Especially when sound needs to be piped out at reverse angles.
In theory, so far this is just a simple ext cab idea that runs from my line out of my amp (Bose or AER etc) or whatever amp I am currently using.
Design is 6 speakers --one on each side of the box and one pointing up towards ceiling(Johnny Smith Fountain of Sound inspired) and one down firing(Acoustic Image inspired). There would be optional screw on legs(a la Fountain of Sound) or you can use an amp stand of some kind.
Simple volume control for each speaker to direct balance towards the angle/band members you need.
Primary goal is to completely avoid beaming in stage contexts as well as address gaps in the projection field. Substitute for additional monitors and PA and to augment the dispersion of a single speaker amp. Also to achieve different sonic results and tune the balance based on position of cab in room.
In my preliminary research this precise thing hasn't been done, or isn't to be found on the market, but please correct me if I'm wrong.
I'm sure the pros will say "it's a bad idea because.." but I'm just curious to have a prototype to try out to see what it does.
The Bose (love 'em or hate 'em) has angled array and the Bill Fitzmaurice XF Guitar Cabs have the 20 degree angle. I'm wondering about the science on speaker angles. In some omnidirectional speaker designs I have seen there is a circular/spherical placement of the speakers. Open to exploring the merits of that. My idea was to keep a standard cab cube but just have access to all the options for speaker output from all the right angles.
Open to speaker brand and type suggestions, but must be optimized for acoustic instruments. Has to be pretty light for transport and this is more of a monitoring solution so no need for huge firepower.
8" might be cool. Maybe 10" for the top and/or bottom?
Anyway, curious to hear your thoughts all!
Thanks
Thanks
