Using Solid Wood for XF210 or XF212
Posted: Sun Mar 20, 2022 4:34 pm
by AxeMan7
I have an abundance of 12" Poplar board that I joined 15 years ago that is 20" wide. Joints are solid and joined properly with any warping.
Is there any reason, other than a potential weight difference, that I can't use this to build my cabinet? I would still use plywood for the speaker baffles.
Re: Using Solid Wood for XF210 or XF212
Posted: Sun Mar 20, 2022 7:08 pm
I don't see any problem at all....
So......you are building a 2x12 cab and loading it with 10s, then you want to build it out of 3/4" solid wood.....hmmmm.....are you a weightlifter and this will be part of your workout?
Posted: Sun Mar 20, 2022 7:26 pm
by AxeMan7
Bruce Weldy wrote: ↑Sun Mar 20, 2022 7:08 pm
I've decided to use the 12". It'll have wheels and I don't have to lift it. Though I could use to build some muscle mass in my old age!
Plus I can't find that plywood anywhere. Even the Baltic Birch is only available in 3/4" around here.
Imagine if the amp head was actually a combo with cab permanently attached.
Posted: Mon Mar 21, 2022 1:29 pm
by AntonZ
Should be perfectly fine indeed. I remember a British niche brand that made very nice bass amps and cabs in solid wood. Could have been mahogany, not entirely sure. Poplar must be a fair bit lighter. It dents somewhat easily. The old back doesn't mind the lighter weight of poplar though.
Posted: Mon Mar 21, 2022 1:38 pm
Fender cabs used to have solid wood top, bottom and sides. Probably poplar, not because it was better, but because it was considered a junk wood because of its green streaks and therefore used to be cheaper than pine. But that was in the 50s-70s, when lumber wasn't farm grown. Pine grows faster, so it's probably cheaper now.
Posted: Sat Sep 10, 2022 12:06 am
by RunTheOtherWay
AxeMan7 wrote: ↑Sun Mar 20, 2022 4:34 pm
Well? Did you built it?
