Trying to Decide What Speakers to Use
Posted: Tue Mar 15, 2022 2:22 pm
I am in the process of building an XF 212 and have the following speakers currently in my inventory.
2x 12" Fender Eminence 8 ohm 50W
1x 12" Celesion Greenback 16 ohm 25W
1x 12" Celesion Relic 30 16 ohm 60W
I also have 4x 10" Celesion G10D-25 8 ohm 25W (I would just cut the baffles on the XF 212 to 10" diameter)
The issue with the double 8 ohm speakers is that in parallel I get a 4 ohm cab, and in series I get a 16 ohm cab. I really want to stay at 8 ohms in case
I am stuck using an 8 ohm only output amp at any time.
The question is, can the 2 Celesions (though different wattage, both 16 ohm) be used in parallel to achieve my 8 ohm cab?
The speakers will never be driven with more than a 25W tube amp.
Looking for suggestions. Thx.
