XF 212 - Applying Tolex and completing the build.
Posted: Thu Dec 02, 2021 2:52 pm
Hi All,
I FINALLY have time to finish up my XF 2112 cab. All of the wood work is done (by a friend, not me!) and now I need to finish up everything else. I have never worked with Tolex before even on a simple square cabinet so I think the slant to this cab is going to be a real challenge. I am assuming the way to apply Tolex to this cab is by having one sheet to cover the top, back, and bottom and then two separate sheets for the sides. I do have the removable panel in the back for the closed/open option. Cutting and folding the Tolex at the slanted corners looks like will most likely draw out rarely used choice words from me along with an occasional flying tool in the garage.
I was planning on using contact cement on both the cabinet and the Tolex. I have heard that some folks use the contact cement on the cabinet and a spray adhesive on the Tolex. What adhesive is the best?
I am NOT planning on adding any type of acoustic foam. None of my production cabinets have any foam installed. Is this imperative to do or can I just skip this?
I am planning on using metal corners on the top and bottom of the back and I guess on the bottom front they can be mounted if they are bent some??? It looks like the top front does not get corners?
I was planning on installing casters. Is this a bad idea or does it matter?
Opinions and guidance would be greatly appreciated.
Thanks,
Tom
Thanks,
Tom
