Table Tuba narrow version
JensToft91
#1 Post by JensToft91 »
Hi all.
Can I expect output at 20-30 hz with a table tuba, corner loaded, 11inch version (narrowest available), with the Day DCS 8"?
How does the width affect the sensitivity?
Re: Table Tuba narrow version
#2 Post by Tom Smit »
Yes, you will get output down that low, I suspect it will be about 3db les than shown here (top trace) viewtopic.php?f=12&t=953. However, it won't be as strong as a wide cab would be. The wider the cab the "more of" there will be.
JensToft91
#3 Post by JensToft91 »
Hmm! Doesn't look like much. I'm not listening to movies very loud anyway - so maybe I can use EQ to flatten the response. As far as I've understood there's more than enough SPL from this thing :clap:
