Hello everyone, I have started the ground work on building an entertainment center and home theater sound system. The attached picture is the center piece which the tv will sit on and there will be built into it a 9 driver horizontal sla cabinet. I will be building two book shelf pieces to sit either side of the center piece and they will house a Tlah each. The bottom of one of them will conceal a table tuba behind some dummy doors.
My initial question, there is a buyout speaker on partsexpress that is real cheap:
https://www.parts-express.com/4-Treate ... hm-299-320
At $4.90 each that would save a ton of money vs the $14 some odd bucks for the normal recommended drivers. Problem is that they are 16ohm rated!!!
I was hoping to build the 9 driver versions but that gives me a 16 ohm load no matter how I wire it. Can I make this work does the filter need to change? Should I pursue use of this driver? Or should I just dine out for the normal recommended driver. This buy out unit only claims 1mm excursion not sure I need any more but it’s nice to have.
Thanks in advance for the thoughts and comments guys I do appreciate the value this forum adds to Bill’s products.
