Nothing like found stuff
Posted: Fri Jun 11, 2021 10:33 am
by Lesknow
Mmmornin! I pulled a 12" JBL GT120 from my car a while back & it's been sitting around. I could always sell it for peanuts but of course I was going to look up the specs first - aside from the fs being lower than these recommended drivers, everything else lines up pretty well for a T48. Thoughts??
Rob
Re: Nothing like found stuff
Posted: Fri Jun 11, 2021 11:16 am
The question is - what are you going to do with it? Put it in the living room for movies? Throw it back in the car? Put it in your shop to play some tunes? I'd say you could do all of those at low volumes.
I wouldn't even consider it for live sound.
Posted: Fri Jun 11, 2021 11:29 am
by Seth
The specs are within range, including Fs, for all the sub designs that can take a 12" driver, with the T60 being a possible exception. (the T60 plans don't list a spec range and I'm too lazy to look up and compare the LAB12 specs)
The reason Hi-Fi and auto sound drivers aren't recommended (recommended not to be used) is the construction materials are usually less than desirable for a horn loaded application and the cones can be damaged by the elevated pressures that are present in a horn. However, like you said, it's something you already have... essentially free. IMO, go for it. If it falls apart, it's only a couple hundred dollars (or less) to get one of the recommended drivers. If it doesn't fall apart, you've got a kick ass speaker cab for peanuts and some hobby time in the garage. :thumbsup:
Out of curiosity, what would you do with it?
Posted: Fri Jun 11, 2021 1:39 pm
by Lesknow
Well, I was thinking the only area that I don't have covered properly so far is the xm radio in the garage, so it'll be stationary, with no plans whatsoever to gig it or rent it out. It's very much not a need that I have, but y'know. Not many of us are having this much fun because we need to, right?? And yeah, it's sitting in the garage already. I figure I'd be a dummy NOT to build a horn around it.
Posted: Fri Jun 11, 2021 2:24 pm
Lesknow wrote: Fri Jun 11, 2021 1:39 pm Well, I was thinking the only area that I don't have covered properly so far is the xm radio in the garage, so it'll be stationary, with no plans whatsoever to gig it or rent it out. It's very much not a need that I have, but y'know. Not many of us are having this much fun because we need to, right?? And yeah, it's sitting in the garage already. I figure I'd be a dummy NOT to build a horn around it.
In that case, have at it.
Posted: Fri Jun 11, 2021 2:35 pm
by Lesknow
:chainsaw:
Posted: Fri Jun 11, 2021 6:00 pm
by Seth
Wait 'til you play your bass through it. :twisted:
Posted: Fri Jun 11, 2021 6:27 pm
by jimbo7
"essentially free" But you have to remember that you'll need to sell a kidney to afford a stack of wood these days
Posted: Fri Jun 11, 2021 6:50 pm
by Lesknow
There is that :shock:
But yeah Seth - in my dreams I'd absolutely tear into a 3015 T48+280 just for the sake of sweet, sweet overkill.
Posted: Fri Jun 11, 2021 7:49 pm
by Seth
With a good EQinf, any T39 or T48 with that driver and one of your Jack's will be pretty epic.
Posted: Fri Jun 11, 2021 7:59 pm
by Lesknow
Hahh, one day ))
