WH6, what radius roundover bit for 1/4" ply
High output and wide dispersion without feedback.
#1 Post by Seth »
What size roundover bit is appropriate to use with 1/4" BB ply? Want the edges to be as "soft" as possible. Is a 1/4" radius bit too much?
Just the outside edges and port/hand hole. Don't want to bullnose the mouth.
Thanks guys :thumbsup:
Re: WH6, what radius roundover bit for 1/4" ply
#2 Post by Grant Bunter »
Hey Seth,
Rather than a round over, I'd be inclined to Aris the wood (ie knock the edge off with a plane) then sand to suit.
Far to easy with 1/4" ply to take to much with a round over, and it's hard to put back again...
#3 Post by Bill Fitzmaurice »
Even using a 3/8" radius only reduces the minimum cross section at the joint by 1/16". A 1/4" radius doesn't reduce it at all.
#4 Post by Seth »
Thanks guys. Much appreciated :thumbsup:
