Page 1 of 2
THT, What to expect from Premium driver?
Posted: Sat Sep 12, 2020 1:55 pm
by El dillo
What to expect from Premium driver UM15-22 vs RSS390HF-4 15".
I´m planning to build a second THTLP and i got some decision anxiety about what driver to go with.
  • Sensitivity ?
  • How much wattage/volt is it safe to power it with ?
  • What does it make it a premium driver (more SPL?)
I do know it got more volume displacement but also lower sensitivity so it should need more power to get the same output and theoretically it would get louder also because of higher VD.
Any other differences you might know...
Re: THT, What to expect from Premium driver?
Posted: Sat Sep 12, 2020 2:28 pm
There's not enough difference between the two to make a recommendation other than to buy whichever is on sale for the lower price. Loaded in the THT you should never approach the limits of either before causing damage to your home. Whatever you've learned or been told about how drivers work in direct radiators for the most part doesn't apply to horns.
Posted: Sat Sep 12, 2020 3:07 pm
by El dillo
Ok, i just thought that the longer xmax was prefered in this case
Thanks for your quick reply.
Posted: Sat Sep 12, 2020 4:00 pm
The longer xmax would only allow you to knock more stuff off the walls and piss of more neighbors. along with the local constabulary. The only thing more destructive than two THT has the name 'Caterpillar'.
Posted: Sat Sep 12, 2020 5:25 pm
Bill Fitzmaurice wrote: Sat Sep 12, 2020 4:00 pm The only thing more destructive than two THT has the name 'Caterpillar'.
Good line....
I'll be interested to hear if that reference translates in Sweden....... :mrgreen:
Posted: Sat Sep 12, 2020 6:07 pm
by El dillo
I am actually after the possibilty to flatten the frequency response a little bit better. EQ does not help over the different seating positions.
Posted: Sat Sep 12, 2020 9:25 pm
EQ can't fix room boundary effects, because as you've found a boost or cut that flattens response at one listening position makes it worse in another. Only with multiple subs can you fix room modes. When you double the sub count you get an immediate across the board 6dB sensitivity increase, which for equal volume halves the excursion per driver.
Posted: Sun Sep 13, 2020 3:51 am
by El dillo
I know, I'm interested in the technical differences about those 2 drivers when installed in the THT.
Posted: Sun Sep 27, 2020 1:23 pm
by daveode
2 THTLP’s here... you can get them flat, and you can get them LOUD with 2. mine are 31” wide. Located at the front and rear of the room mouths about 20” away from the corner. My bass is even enough for my room. I’m using the RSS Dayton subs.
Posted: Fri Oct 02, 2020 7:36 am
by hotbutta
I found a SUPER PREMEIUM driver. Over 28mm Xmax. I'll show my rafters who's Boss. I have two of these going in my 29" THT's this Sunday.
https://stereointegrity.com/product/sql-series-15/
Posted: Fri Oct 02, 2020 1:46 pm
by caddylackn
The more power you give them the harder it is to hear normal speaking dialogue while watching movies from all the rattling. I get so much noisy vibration from wall hangings and rattling windows at higher than normal volumes that it is not an enjoyable movie watching experience even though the bass is killer. I doubt I give mine much over 100 watts before I call it quits. At some point, you will have to worry about damaging your windows, although you will probably damage your hearing first.
Posted: Fri Oct 02, 2020 4:54 pm
by Grant Bunter
hotbutta wrote: Fri Oct 02, 2020 7:36 am I found a SUPER PREMEIUM driver. Over 28mm Xmax.
I'm not seeing any Xmax value in the link you posted.
2 x recommended Daytons would be about the same cost as one of those drivers.
Posted: Fri Oct 02, 2020 7:21 pm
by Rich4349
Posted: Fri Oct 02, 2020 11:05 pm
by hotbutta
Grant Bunter wrote: Fri Oct 02, 2020 4:54 pm
One of these has over twice the Vd as the recommended Daytons.
Posted: Sat Oct 03, 2020 12:17 am
by Grant Bunter
hotbutta wrote: Fri Oct 02, 2020 11:05 pm
That might mean something if you needed it, but it's not like you're going to drive the cabs to max output anyway.
Enough is still enough...
