T60 Build, almost done
flashero
#1 Post by flashero »
Hi!, how are you people. I have finished the build, the only remaing tasks is to load the cabinets, put the speakon connectors, some cab corners, and perhaps add a grill. When its all done, I will post some measurements, I will compare with the old BR cabs i'd made for the LAB15 (med size vented club sub https://www.eminence.com/pdf/LAB_15_cab.pdf).
I attach some pictures.
Best regards!
Dale Hammer
Re: T60 Build, almost done
#2 Post by Dale Hammer »
Looks great! Nice work.
flashero
#3 Post by flashero »
Dale Hammer wrote: Thu Aug 27, 2020 7:55 am Looks great! Nice work.
Thank you Dale!, can't wait to fire them up and shake some bodies :)
#4 Post by Seth »
flashero
#5 Post by flashero »
SethRocksYou wrote: Thu Aug 27, 2020 9:04 am Here's some music to let those beasts do some justice to...
https://www.youtube.com/c/Siryn/videos
https://www.youtube.com/channel/UCkt2uC ... pCQ/videos
Thanks, I will try them soon :)
#6 Post by Grant Bunter »
Nice!
What will you be using to as a limiter?
flashero
#7 Post by flashero »
Grant Bunter wrote: Thu Aug 27, 2020 3:54 pm Nice!
Thank you!. Now I have an Ashly Protea 4.8, but I was going to use a plate amplifier with dsp. With shipping overseas expensive, perhaps I will buy a 4 CH class d amp with dsp (Powersoft Clone), soon I have to decide.
#8 Post by Grant Bunter »
Let us know what you’re going to do...
#9 Post by Seth »
I'd recommend using the Ashly for your signal processing and forgo any dsp in an amp. When viewed on a PC, the Protea software is super easy to use and the limiter is very effective. Although, as is the case with any limiter, it needs to be set up properly to work properly. If you're not absolutely sure how to do it, search the forum here, or as Grant mentioned... just ask.
Can't wait to hear your review! :thumbsup:
