SLA PRO PA TOP For Announcing/Sound Effects, Sirens, etc
johnb11
#1 Post by johnb11 »
Ive been researching about for quality sounding public address systems, speakers, or PA bullhorns for my security camera systems.
The problem is there is very limited weatherproof self amplified/active speakers that have any clarity or power.
large PA Horns that are barely decent need to be amplified. They cost couple hundred bucks for an amplied tweeter in a horn, plus an amp, etc...
My thoughts were to build the SLA PRO PA TOPs and weatherproof them. Each camera will have one speaker. Single channel mono for a total of 10 cameras, (10 speakers).
Will the sound from one SLA PRO TOP speaker reach a similar distance as a single 50 pyle horn speaker link https://www.walmart.com/ip/PYLE-PHSP4-6 ... lerId=2605
Thx
R
Re: SLA PRO PA TOP For Announcing/Sound Effects, Sirens, etc
#2 Post by Chris_Allen »
Hi John,
You have multiple questions, so I'm just going to tackle a few to start with. What do you intend to play through the speakers? The SLA Pros are probably good down to about 120Hz for the 4 driver version, and I'm guessing at around 150Hz for the 2 driver version.
SPL drops by 6dB per doubling of distance, so if you know how much SPL you want at a given distance, we can work back from there.
The TLAH Pro with cheap drivers might be a better shape for weather sealing as well as being able to reduce the driver count to tailor the frequency response for the application.
Chris.
#3 Post by Bruce Weldy »
Chris_Allen wrote: Thu Apr 23, 2020 3:18 pm The SLA Pros are probably good down to about 120Hz for the 4 driver version, and I'm guessing at around 150Hz for the 2 driver version.
Considering that the speakers he referenced only go down to 500hz, I'd say anything would be a great improvement. But, it's also much easier to waterproof those little plastic horns. So, everything is a trade off....
