First build - SLA, TLAH
Posted: Tue Apr 14, 2020 5:03 pm
Hello all,
This is my first post, and my first BFM builds. I’m building a pair of TLAH’s for front mains, a 9 driver horizontal SLA for center, and a pair of 6 driver SLA’s for the surrounds. I also plan to add a Tuba HT. These will be upgrades for my outdoor theater, 10’ screen hung on the house, viewed on a 24’w x 18’d concrete patio. I’m also lucky to have a corner for the sub.
I have a question about glue. All the BFM plans I own say to use the PL premium except the SLA plans. Is there a reason for this? Was this an oversight?
I built the boxes for the SLA surrounds first as they seemed the easiest of the bunch, and I wanted to try to miter all the edges so there would be no exposed plywood endgrain at the corners or along the baffle. I used the quick grab PL Premium to help keep all the parts from sliding round while I brad nailed. I’ll need some wood putty here and there on the corners but I’m happy so far.
When I build the horizontal SLA, would I be better off with wood glue, or should I use the regular PL? I’m using 3/4” solid Maple for the baffle pieces, with the rest plywood with veneer to hide the end grain, and I plan to finish all the cabs with a black stain and multiple coats of satin polyurethane.
Thanks for any insight,
Dom
Dom
