OmniTop 12
Locked
OmniTop 12
#1 Post by Bill Fitzmaurice »
A Deltalite II 2512 loaded OTop 12 w/piezo array compared to the Yamaha Club series 112v and 115V:
If you want to line array commercial cabs you can't do it on the cheap. Here the OTop 12 is compared to the $1200 Peavey Versarray 112:
Now the OTop 12 and the $2100 JBL VRX932LA:
OTop 12 and the Turbosound TMS High:
Here's a 3012HO loaded OTop 12 compared to a Mackie 1x15 SA1521z.
The Mackie is considerably better below 100 Hz, but that only matters if you're running with no subs. Above 100Hz the Mackie doesn't make the grade.
3012HO/NSD2005 loaded OTop 12 and the $4900 EAW kf730:
Locked
