SLA Pro X-over - in a tight, can i do this?
Posted: Wed Sep 25, 2019 10:50 am
I have some off-the-shelf 12db 3.5k high-pass crossovers (Dayton Audio from Parts Express - $7 or so each... cheap but simple stuff.)
I'm in a time bind right now since EVERYTHING i've ordered since last Friday has either been delayed or just flat out not filled completely, which has me in a pickle.
Can I use these crossovers for the tweeters in the SLA Pro (2x6)?
I do have some 30 Ohm and 4 Ohm resistors I could wire into it to make it like the plans, but I don't have the crossovers in front of me as I type this to verify the Cap & Coil values of the pre-rolled crossovers.
My goal is to run the 2x6's with the 4x6's simultaneously if that makes a difference.
Help much appreciated.
Thanks,
Tim
Thanks,
Tim
