Page 1 of 2
2 x Tuba 45 build
Posted: Sun Jul 21, 2019 2:08 pm
by rfauske
Then I have started ny Tuba 45 build, trying to get it done during the week.
Glad that I got an flatpack, it almost feels like cheating when building it.
Re: 2 x Tuba 45 build
Posted: Mon Jul 22, 2019 10:24 am
by J_Dunavin
Looks good!! Don’t forget to really glue up those pieces before you lay on the side piece.
Posted: Mon Jul 22, 2019 12:50 pm
by rfauske
I noticed, have dry fitted the side now and needed quite a bit of force to line things up som letting it sit over night before double checking things and clearing out the dust.
The air is quite damp so that could have dome to do with it..
Posted: Mon Jul 22, 2019 2:12 pm
by J_Dunavin
Tip - It took some extra time, but i drew the horn path on the outside of the 2nd side piece, which you are basically copying the 1st couple of steps on the build. This way i knew where to drive the screws into when i placed that piece on.
I also left a little extra on that side piece, so i could just router it flush afterwards, since i have a hard time keeping things perfectly square.
Posted: Mon Jul 22, 2019 2:27 pm
by rfauske
Thanks for the tips. I have already predrilled the other side som it should work but I Will check a bit so that things hit the plates inside.
Posted: Tue Jul 23, 2019 4:19 pm
by rfauske
Looks like it will turn out fine
got it ligned up rather nice and will do some sanding and router work tomorrow . Biggest problem was to mount side two fast enough for the glue not to dry
Posted: Wed Jul 24, 2019 12:42 am
by J_Dunavin
Sweet!!
What’s that slot in the side?
Posted: Wed Jul 24, 2019 1:12 am
by rfauske
The slots are for sliders when stacking.
Same way as you can see here
viewtopic.php?f=26&t=25291
Posted: Wed Jul 24, 2019 7:58 am
by J_Dunavin
Ooo that’s cool!
Posted: Wed Jul 24, 2019 1:10 pm
by Seth
Looks really good.
It's difficult to tell for sure in the pics, but that looks thicker than 1/2" / 12mm ply throughout. Or, is it only the exterior panels that are thicker?
Posted: Wed Jul 24, 2019 1:59 pm
by rfauske
The sides and long side with handles are 18mm, mostly because of how its cnc'ed I think. So its a bit heavy
Posted: Mon Jul 29, 2019 3:21 pm
by rfauske
Going slow but steady
Posted: Mon Jul 29, 2019 11:30 pm
by J_Dunavin
Looks great!!!
What’s the width?
Posted: Tue Jul 30, 2019 12:44 am
by rfauske
Just below 16", its all that I can fit om ny pack space. Have one og these going in to each
Posted: Tue Jul 30, 2019 2:23 pm
by rfauske
Just the side panel left, tested it a bit without it just to test that the amp and speakers works and I think this is going to be some serious overkill for what I need. But thats just cool
Its impressive how little cone movement is needed to make a lot of sound out the horn.
