SLA Pro Micro??
Posted: Tue May 07, 2019 2:45 am
				I've searched the forum but not found any info on the smaller SLA PRO MICRO options other than Bill's post introducing the updated plans with the Eminence alpha 4" option a couple of years ago and the very recent note from Bill about the 5" Eminence becoming unavailable and the Faital Pro 5FE 120 being the new recommended driver.  I'm not seeing anything on any builds with the 4" or 5" drivers.  I have the old SLA plans from when it was first introduced with the original Pro version using four Alpha 6's, but was curious about these newer, smaller options.
In particular, I was curious about the Alpha 4 and the big jag in its response curve where it has a pretty quick 6db drop between roughly 1400 to 1800 hz, and after that a more gradual rise back up and then another dip centered at about 6k, though it's not as deep or as steep. The midrange dip seems like it would require a good bit of eq to smooth the sound out. Wondering if having 4 drivers in the array helps that at all. In that regard the 4" Faital drivers response chart seems a lot smoother, but of course are slightly more expensive for the ferrite drivers. They do have the super light neodymium versions as well, which though even more expensive offer a significant weight advantage.
Anyway . . . Parts Express describes the Alpha 4 as having a "flat response from 90 to 12000 HZ" but when I look at the chart it certainly doesn't look all that flat so just wondering how these sound in actual use, and again I'm not seeing anything on the SLA build using these when I do a search in the forum. For my purposes minimal EQing is preferable as I don't want to have to haul out my drive-rack/amps/mixer etc if I can get buy on a simple lightweight powered mixer for a basic guitar/voice gig. (Note also that the newly recommended Faital 5" looks to be much smoother in it's response curve than the Eminence 5" though it is slightly less efficient.)
