Pair of Omnitop 212s and Titan 39s
Posted: Thu Apr 11, 2019 9:09 pm
Started this project mid March, working a little at a time. Previously built 2 Omnitop 12s and I'm a woodworking newbie with few tools but I'm having fun, learning some skills, making mistakes, getting frustrated at times, but at the end of the day feeling very satisfied accomplishing something. The Omnitops will be loaded with Eminence Delta Pro 12-450A wired in parallel and Kappalite 3012LF in the Titans (20" wide).
Start of build Mid - late March:
Most panels in place and you can see an Omnitop in the upper right.
I don't think the panels on one of the titans are perfectly straight, when I put the side on everything is kinda twisted about a quarter inch. The top, back, and bottom panel are in good alignment. I'm thinking of cutting a long skinny triangle piece to fill in when the side goes on. Next time I'll use some taller jigs and check carefully. I'm thinking I'll need at least a couple more Titan's to keep up with the tops, they'll mostly be used with house and other electronic genres. The Omnitops are basically ready to go just need to attach the back, of course as soon as I'm almost done, a cold & windy period has settled in for the weekend
