SLA Pro 5 inch Drivers
Short and Transmission Line Arrays for Pros
Locked
#1 Post by Bill Fitzmaurice » Fri Mar 22, 2019 5:22 pm
The Eminence Pro 5W driver has been discontinued. The recommended driver for the five inch woofer version of the SLA Pro is now the Faital Pro 5FE 120, available at www.speakerhardware.com
The cabinet design is unchanged except for the baffle, which has different hole spacing and sizing. If you want to use the 5E 120 you'll need to update plans purchased prior to March 22, 2019. Standard procedure for getting updated plans applies.
Locked
