Christmas SLA Pro build
Posted: Thu Dec 27, 2018 12:15 pm
Took a couple days over the break and built the SLA Pro's I've been asking about lately.
Very, very happy with them. They are my new favorite tops for small/medium indoor gigs.
I expect they will probably prove useful for some corporate work and wedding ceremonies in venues without suitable sound reinforcement.
Coupled with a pair of T39's they are sounding great.
I'm so pleased with them that I am going to take them out tomorrow night for prime time.
ALMOST got both pairs built out of one sheet of 5x5. I think I got everything but the bottoms out of it. Might could have squeezed it all into one, but my goal was to cut all of a given dimension at the same time.
The build went pretty smooth. Only trouble spot was when I tried to go above and beyond and roundover the port/handles and used a 3/8" roundover. That threw the bearing just under the ply in the radius portion (it worked fine on the straight portion because I had lined them with a piece of half-round for carrying comfort.) A little sanding and then changing to a 5/16" roundover worked perfectly.
Side note: I did NOT stick my hands in any PL during this build!
(I did get a bit covered in Duratex and flat Black, but that washes off.)
Completed weight came in at 34.4 pounds per cabinet.
Some of the clearances on this design are nothing short of amazing - well, that can pretty much be said for most of the other cabs I've built here as well.
Anywho, pics are here: https://photos.app.goo.gl/HCjGcVmSvk2MYbNZ6
One thing I have noticed - when on the speaker stands they lean just a bit to the side of the woofers. I assume this is just due to the weight of the magnets on the 6.5" drivers. Any easy solution to straighten it up? Not a deal breaker, but if it can be remedied it'd be even better.
Thanks!
Thanks!
