upstarts needing amp info.
Posted: Mon Nov 05, 2018 7:25 pm
Hi, my husband and I are working on developing a business which involves dance music and music to lounge and relax to. We plan to reach out to our friends for support and good times. We have invested a lot in the music already and Now, our next step is to equip ourselves with the best audio equipment.
After doing a thorough search online and seeing what's out there among company manufactured subwoofers, Richard has found that Mr. Fitzmaurice's Tuba 60's with the Eminence Lab 15 have extend further down in pitch than any other he's seen online. They are the more cost effective and it will be personally more rewarding to build them than to have them handed over to us by a retailer.
Our objective to build 3 Tuba 60's, one for indoors, two for outdoors which will be playing at the same stage at the same time and to build four DR 250's two for indoors, two for outdoors, with Deltalite-II-2510 woofers and 20 Goldwood-GT-1010 piezos in each box.
We would like to know what are the best amps for the indoor and outdoor combos. Maybe two amps are needed for each? Richard is confused because he doesn't know if 6 (Lab 15) and 8 ohm (Deltalite-II-2510 and Goldwood-GT-1010) speakers/tweeters can be connected most ideally on one amp.
All we know, and this is old news to him, and he doesn't know if this current, is that Crown manufactures the best amps. Is this still true? Saving so much because of the speaker components, we won't mind to splurge for the best! We'll probably have the same balance, or still have less cost, then if we were to by manufactured audio equipment.
We would like to buy a Canadian store, so here are our options. There are two stores to consider:
https://www.long-mcquade.com/department ... sovers.htm
https://www.avshop.ca/sound-amp-pa-audio/amps (this one seems "better/more options" says Richard.)
Is there anything else we'll need from these stores for audio equipment?
Could some of you offer us some good and consistent advice? We would only like to invest in this pro audio equipment after we have found consensus on this board, so feel free to discuss (if needed)! Thanks in advance!
Nancy & Richard Bornyi
