HT Build: TLAH, SLA curved, TTLS
billkatz
#1 Post by billkatz »
I'm finally getting going on my TLAH and SLA ccurve build. All of the panels are cut, the TLAH boxes built, and the plywood is ripped for the TTLS - I just need to do some cross-cutting and of course cut the angles for the braces.
Here are the TLAH boxes getting started:
At this point I plan to rear mount all of the drivers and finish the boxes in stain/polyurethane.
The first batch of drivers is in hand from Speaker Hardware.
I also plan to build the SLA surrounds from the plans.
My next big challenge is to cut a whole bunch of woofer holes.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
y2kindyz
Re: HT Build: TLAH, SLA curved, TTLS
#2 Post by y2kindyz »
Looking good, looking forward to seeing the finished results.
billkatz
#3 Post by billkatz »
After discussions here about the best way to make the woofer holes, I tried:
  • A holesaw
  • Router, up-spiral, jasper jig,
  • template and pattern bit
I decided that the jasper jig was the easiest, as I just need to drill a 1/8" pilot hole through the baffle (and into a backing board) and then use the jig.
First I tacked the curved SLA baffle to my work table with a few brads, nailing in the 1/2" wide strips that would be cut away:
Then using the router, spiral bit and jasper jig, cut the woofer holes:
I used a Forstner bit for the tweeter holes - it makes a very clean cut. Here is the baffle with all 12 holes:
Next I changed out the plunge base for the regular base, and mounted the 3/8" round-over bit and rounded off all of the holes:
The final step was to make all of the angled cuts in the panel, leaving me with 8 pieces. Here is a dry fit of them standing up:
A careful reading of the instructions reminded me that I now need to sand and finish these pieces before I glue them together. I also need to make the jigs that will allow me to make symmetric pilot holes for the mounting holes for the drivers. Tomorrow while the stain and polyurethane are drying, I may try to get the first couple TTLS panels assembled.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
#4 Post by Bill Fitzmaurice »
Put the finish on the inside of the top and bottom before assembling as well, masking off the glue line.
billkatz
#5 Post by billkatz »
Bill Fitzmaurice wrote: Tue Apr 24, 2018 8:53 pm Put the finish on the inside of the top and bottom before assembling as well, masking off the glue line.
Thank you - I see that in the plans.
I hope it will work to build the baffle out of 1/2" Baltic Birch rather than 3/4" solid wood. Otherwise I need to start over on the baffle.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
ketoet
#6 Post by ketoet »
My tlah baffles are made out of 1/2 birch plywood and didn't give me any trouble. Plywood doesn't split like solid wood might do. Just make sure u use screws that aren't too long and show through.
Mine are painted white the plys can be seen but i like that.
Greetz ketoet
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
billkatz
#7 Post by billkatz »
I'm making a little more progress - I started on the TTLS.
Here are the first 3 panels installed:
I also have panel 4 in. Now I need a driver before I can go an farther. Perhaps I'll order it today. I'm leaning toward the 10" Dayton.
I went down to work on the jigs for drilling the mounting holes for the SLA/TLA drivers today, and promptly dropped the router and broke my only 1/4" upspiral bit :-( So that will have to wait. My current idea is to use the jasper jig set to 1/2" larger than the holes to produce wooden slugs that will fit exactly into the holes - and then use a bit of 1/8" masonite as a guide for the 4 pilot holes.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
billkatz
#8 Post by billkatz »
Only 2 1/2 years later, I am finally making progress on this build again! We are doing a major house remodel, and I want to set up our new den as a home theater (or at least have really good audio when watching TV)
One of the things that took forever on the curved SLA was the decision to rear-mount the drivers. I needed to build templates to accurately place the 4 mounting holes for the drivers. Here are teh jigs I built:
After drilling mounting holes and mounting drivers, it is starting to take shape:
The woofer template uses a wooden disk to center it, while the tweeter uses a bit of 1 1/2" drain pipe. I also went through several iterations before settling on 5/8" long screws.
Here is the finished speaker:
I decided that for the TLAHs I would front mount the drivers. I also changed course and decided to use the Dayton driver instead of the Goldwood. It is lighter, and (in another thread) Bill recommended it. It has a built-in gasket on the back, but needs an annular ring for the gasket to sit in. I used the router and Jasper jig to rout out rings 4 1/16" in diameter and 1/16" deep:
Next I routed holes 3 11/16" in diameter. I needed to clamp a piece of scrap inside the enclosure to hold the disks that were being removed and keep the router centered. Here are the first set of holes:
The tweeters fit nicely in 1 15/16" holes made with a Forstner bit. Here are teh two enclosures drilled and stained, ready for poly:
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
#9 Post by Tom Smit »
Shoot, I just finished going through my Facebook feed, and now I was looking for the "like" button.
Looking good, so far. Keep it up.
billkatz
#10 Post by billkatz »
I have finished my pair of TLAHs. Now if the contractor would just install the roof on my addition!
First I mounted the woofers - the annular ring fit pretty well, but could have been a 32nd deeper:
Next I installed the wiring:
Then I added batting. Ordered on Amazon, 2 yards x 48" was just about right for a pair:
Then with two of them, and my eBay 16 channel amp, at last a test:
They sound quite good, although there is clearly bass missing. I didn't try dragging one of my Titan39s up :)
My next question for the group - any suggestions on hardware for hanging them from the wall? I plan to put the TV on a wall mount and place these on either side.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
#11 Post by Seth »
Those look great Bill :thumbsup:
billkatz wrote: Tue Sep 29, 2020 5:22 pm My next question for the group - any suggestions on hardware for hanging them from the wall?
A simple French Cleat should do just fine.
Dale Hammer
#12 Post by Dale Hammer »
Yeah, French cleats are the way to go.
billkatz
#13 Post by billkatz »
SethRocksYou wrote: Tue Sep 29, 2020 8:01 pm Those look great Bill :thumbsup:
Thank you! That looks like an excellent idea. It might even work to hold the curved SLA center channel on the wall.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
#14 Post by Bruce Weldy »
Cleats are wonderful. I've used 'em for hanging cabinets, light sconces, etc. Forms a tight seal to the wall. Best part is that all you have to level is the cleat on the wall - whatever you hang will be straight.
