Can't find 1/8 inch birch?
#1 Post by Bill Fitzmaurice »
hclague
#2 Post by hclague »
This place MANUFACTURE's the bendable plywood:
Buffalo Veneer & plywood co
501 6th Ave NE
Buffalo, MN , 55313-1655
Phone: 763-682-1822
FAX: 763-682-0795
Hal
Re: Can't find 1/8 inch birch?
#3 Post by DJPhatman »
Bill Fitzmaurice wrote:This place has 3/8" and 1/8" bendable ply:
http://www.vandykes.com/product/02007824/
http://www.vandykes.com/product/02013190/
Bill, can the 3/8" be used for builds? BB is totally unavailable around me. I live close to Tim Ard, but he tells me he can't get BB either.
BTW, I want to build a fleet (8 total) DR250s and T48s with it
David Carter
#4 Post by David Carter »
I purchased the 1/8" bendable Italian Poplar from this site for use on a couple of DR250's. So far it seems to be holding up in the horn throat assemblies (haven't done the rear sheaths yet). However, be aware that it is single ply with a veneer layer on one side. I used a dovetail saw to cut off the overhang when putting together my horn throat assemblies, and I had to saw in one direction only. If I went the other way, the plywood would tear away from the veneer face.
Dave
- 2 x Titan 39 (BP102 - 14"W)
Mark Coward
#5 Post by Mark Coward »
The 3/8" bendy ply I got locally was 3 even layers, no veneer - the surface was pretty rough, but made for some strong butt cheeks. If you're boxing in the back anyway it would be overkill.
Mark Coward
jollygt78
#6 Post by jollygt78 »
this company also offers flexible plywood. i came across them when i was looking for drum shells..
http://www.aitwood.com/
el_ingeniero
#7 Post by el_ingeniero »
at Rockler's, I got 4 20"x30" panels for $7 each or so. They had smaller panels, but they are cut to bend on the short axis, not the long.
