SLA Home Theatre Build - UK Newbie Alert
Posted: Tue Mar 07, 2017 10:17 am
Hi all,
Relatively new to the forum, getting ready to start my first build, a home theatre setup with 2 x 4 speaker SLAs as fronts, a 6 speaker curved SLA and 2 surrounds. Bought the plans for all at New Year and thought I'd create a build thread to show progress and beg for advice when it all goes catastrophically wrong. I’ll probably build a Tuba 18 to go with this and already have the plans. I also have the plans for the David stereo floorstanders and hope to make those eventually.
This is the first time I've tackled a project like this so any help is warmly appreciated. I've checked other build threads and have studied the plans again and again.
So:
Drivers bought - went with https://www.pollin.de/shop/dt/NTgxOTUzO ... _100D.html as recommended by Bill in this thread http://www.billfitzmaurice.info/forum/v ... =5&t=24010
Tweeters - http://www.pollin.de/shop/dt/MDI3OTUzOT ... ttro_.html I know the drivers I have should be fine by themselves and this will make the build cheaper and easier but I want to include the tweeters so I can play with my soldering iron and build the crossovers.
Crossover parts purchased from Falcon Acoustics.
Plywood bought from Beers.
I've used an app on my iPad called Optimise to do a cut list and I’ve already marked off all the cuts and started to make some sawdust. First thing I have learnt, I can't draw/cut straight lines. Good job I've got an electric sander for trimming.
My plan is to build the fronts first as they look easiest. I can then listen to music on them in the garage whilst I build the centres and surrounds.
That's all for now, I'll try to update this regularly.
So:
